Kobelco hydraulic excavators
blankey85
SW PA
I'm having trouble diagnosing an issue with a 2004 Case CX-14. I'm not sure who is the actual manufacturer being as the service manual also applies to a Kobelco SK13SR.
It has Kawasaki pilot valve body and a 3-cylinder Yanmar engine. I've posted looking for help with a hydraulic issue but haven't gotten any responses. So is this machine actually a Case or Kobelco?
bigjimcor
massachussetts
hello i have a jsw BH80E s/n s5 -1092 IM having problems with the main pump im not sure how to set it have been looking for a repair manual for the machine i recently had pump resealed everything looked fine but the popet settings im not sure how to set any books or info on it would be greatly appreciated. tks jim
heavyrig
Hot Springs, AR
I have a MDI Yutani MD180 and am needing the part numbers for the hydraulic filters. There are two. One big one in the main tank and one in the return for the hydraulics.
Fordson dexta
UK
Hi all.
I have chance of buying this digger in the pictures, think it is a SK50-05736. But a bit vague at the moment. Not entirely sure on year of manufacture but I have the serial number so guess this can be worked out.
It is fire damaged, engine wiring loom is burnt out, the engine will run and with a bit of messing around I am told the hydraulics will work, but obviously needs a fair bit of fixing.
Is it worth a go, are they any good? No experience of Kobelco, have a Komatsu though. Are parts, possibly a loom easy to come by, is there anything I need to be weary of?
It doesn’t look to bad, been parked up for at least two years, so a bit green, doesn’t look to burnt and charred.
TIA.
mudober
So. IL.
heavy equiptment operator
Sk150
Hello, I am looking at buying a 98 SK150 LC -4, for farm use. I believe it may need some new track chains. I am thinking they will cost around 3,000 for a pair. Am i about rite? Do you believe that this is a good series of machine. It will have a Cummings engine. Thanks for your insight. Mudober
Colorado Digger
Carbondale,co
Hello all, I bought a 06 sk350lc at auction and it had been running fine. We brought it up from DFW and it ran for the first month perfectly. Then the turbo went and we had it replaced. Now the machine is blowing a lot of smoke, like it is unburnt fuel and may be too rich. I have talked to Kobelco and they said they have seen the problem before. Last week the mechanics were at Hino school and will be back Monday. They are going to send someone up to update the computer. Anyone have experience in this?
Thanks,CD
Splash
New Zealand
Hi
Anyone know what the electrical switch in the toolbox of an SK100W is for? little push button switch mounted top right of the tool box.
Oxbow
Thanks,CD
CD, could it be that the turbo failure may have plugged the aftercooler? I don't know anything about your machine, but it seems plausible that if it did not smoke before and suddenly began after changing the turbo that there is an air restriction somewhere (assuming the correct replacement turbo was installed). If the old turbo scattered then you would have residual pieces in the charge air cooler, and if it lost seals it may be plugged with oil.
Plebeian
NZ
Kobelco SK135SR vs Kobelco SK135SR-LC, is the LC with the longer tracks likely to be a better machine for working on slopes or is the standard SR tracks with less weight and less track length to power likely to have better climbing ability?
qball
il
local 150 operator
Just spent the day on an sk500. Phenomenal hoe, incredibly fast, smooth and powerful. Very impressed.
digger_hunter
Massachusetts, USA
Hi guys,
Our Kobelco SK210-6 has developed a weird problem or we just didn't notice is before we bought it. Bascially when you move the arm in, towards halfway of the stroke when the arm is just outside of being vertical to the ground, the arm just falls about 6-10inches and bounces a bit and stope moving inwards. So its kinda like 10 inches before vertical its almost like the pressure on the return line drops or something and the arm just falls down and then the pressure seems to catch up after 2-3 seconds and it continues to move in. Pretty weird.
Would be grateful if someone can point us in the right direction.
Thanks
samsonv8
uk
sk75ur
hi first time on here, have a sk75ur,yr 03815.very low on power, poor at climbing and digging, engine ok ,all filters changed .noticed some times the blade will not power down ,any ideas .thank you
Pagey
Sydney, Australia
Hi, First time on the forum. I have a Kobelco SKO45 just using it on the farm, digging trenches, removing stumps, moving dirt and general lifting. Can someone tell me the capacity of the hydraulic system? I have a light on the control panel that I think is "low oil", I have topped up with 15L but still on? Thanks in advance for any assistance.
racecoach
Montreal
Business
I am looking at how to take off the drive engine cap to fix a seal. The drive engine is loosing it's oil on both side.
Can anyone help me with this?
Model Kobelco SK-60 Acera
Thanks
Patrik
racecoach
Montreal
Business
Cap removal on drive engine SK-60 Acera
Hello I'm looking at how to remove the cap from my drive engine on my SK-60
Anyone has the know how?
Thank's
Patrik
