Mike L
Could have been much worse than just a belt. That's just typical rushing to get **** done and on to the next job stuff.
you are absolutely right.
It’s been pretty good. I had to replace some spring pins and bushings, air bags, leveling valves, etc, to get rid of a bunch of rattles and make it sit right but I’m happy with it. Typical used truck stuff.How's the new truck?
I would have used the combustion gas tester but the coolant was pushing so hard I didn’t figure I’d get an accurate read.That's the test I did on a few older engines. Worked a lot better than the dye test for compression in the coolant.
