Well I’m asshole deep in the C18. Dropped a liner, wiped out the head gasket. Dry fit the liners and my protrusion was way off. Had to send the block to New Hampshire as cat had nobody in maine to cut the counter bores. Operator took it down this morning, dropped it off and toured around while it was being done. Guy cutting bores called him and said there were marks on the liners. Apparently when I checked protrusion the washers on the bolts left light marks on the liners and he said they were now not any good. I haven’t seen them yet but new
liners and a new spacer plate were ordered. So cat gurus what did I do wrong? Back in my truck days we did a pile of C15 overhauls. I installed the spacer plate gasket and spacer plate, dropped liners in without seals, put 6 short bolts in and torqued down to 300 ft lbs. then I measured protrusion. The only thing I can think of is over torquing the bolts or I needed 2 washers on each bolt to not leave a mark on the liner. My memory isn’t great anymore but this is how I remember setting them up. What say you?
