Here is a copy and paste from the 310 manual. There are a few pictures that didn't follow along. Also, like most manuals, when reading one section, it refers you back to other sections of the manual. I edited/added to the following text the best I could to eliminate some of the confusion this would cause. If you need clarification on something, let me know. You may want to consider purchasing a manual. I bought mine on CD from
www.johndeeretechinfo.com It was under $50.
REMOVING AND INSTALLING REVERSER HOUSING
Removal
Raise loader to full height and support boom by one
of the following methods.
1. Attach a piece of angle iron to the boom cylinder
piston rod between the rod end and the cylinder barrel,
being careful to avoid damaging the piston rod.
Be sure the angle iron is large enough to rest against
the cylinder barrel and not against the head casting.
2. Use prop under cross member to support boom.
3. Chain bucket to hoist or overhead beam.
Disconnect battery ground strap. Drain oil from
transmission. Bleed down accumulator by operating
steering valve.
Disconnect all connections between clutch housing
and engine
Remove operator’s seat and floor panels.
Disconnect main pump pressure line at pressure
control valve on right side of transmission.
Insert wooden blocks between front axle and front
end support to keep tractor from tipping.
Place solid blocking under loader frame and remove
cap screws securing loader to front end support
and canopy brackets to flywheel housing.
Support rear of machine and front of transmission
case with solid blocking.
Install two JD-244 engine lifting adapters in engine
cylinder head. Attach JDG-1 sling to adapters and to
A-frame hoist.
Fig. 8-Engine Attaching Points
Remove reverser housing-to-engine cap screws.
With the aid of a hoist, roll engine with front end
assembly away from reverser housing.
Disconnect all the necessary wiring, linkage and
hydraulic lines between upper cowl and reverser
housing. Disassemble upper cowl from top of reverser
housing.
Disconnect and remove the brake valve and transmission
shift cover. Remove transmission-hydraulic
oil filters.
1 -Reverser Housing 3-Transmission Shifter Cover
2-Transmission Case 4-Attaching Points
Fig. S-Reverser Housing Attaching Points
Position a chain hoist around reverser housing.
Remove cap screws securing reverser housing to
transmission case and remove housing from transmission.
