You can take a swat at me if you like but these engines have been my life! In challenging me you have also taken on alr man , pumpguy and several others on this post. When someone puts an incorrect piece of info up here it needs to be dealt with. I cannot help it if you don't know a 4 cyl from a six, then call me ignorant in so many words. I have replaced hundreds of pumps in my career, mostly Roosa/Stanadyne, disassembled them made repairs and reinstalled them and no one needs to school me. I have never lifted a valve cover to find tdc, it is not needed to get the engine close enough to install the pump and do final timing at the flywheel markings. Not one of us was advocating running it out of time, just said it was close enough that it should run. I have seen customer units come in with the pumps jacked clear against the end of the slots to compensate for failed advance circuitry and never seen an engine burn down from that. That idea that a diesell will burn down because of a couple degrees timing error is much overblown.
Back in the 60s I installed turbo kits by M&W and part of that installation was advancing the timing 5 degrees to optimize power, some of those engines and sill running to this date. None burned down, and they are still in my territory
I have since retired from 52 yrs at the same dealership and am well respected here on forum in both diesel and hydraulics and have done phone consultation with fellow forumers to complete resolution of their problems, so I do not believe your haughty attitude is going to affect anyone's opinion of me. alrs, pumpguys, my and several others advice was spot on telling him to line up dot to dot. In one the man's first posts he affirmed that the engine had not been apart so with that info given forumers were acting on that. When that is done the engine will run and nowhere did I infer that was the end of the process. BTW, I don't ever remember you having to clean up any of my messes. The point is, the procedure for installing that pump was being made way more difficult than needed. I have put information up here that most never knew about even regarding the 0 advance kits supplied to Case to change starting timing on 580C backhoes to enhance the starting characteristics, probably something you were never aware of.
I have said all I am going to say into this matter, just be careful when you put info up here that proves you don't have a clue about the unit being worked on.
