Could be a stuck valve, or one out of adjustment, blown head gasket, loose injector... am I missing anything?
So, the heads were changed. But now you have the original pump installed that matched the older injectors. Is that correct ? Hopefully one of the pros here will advise you if that is acceptance situation. Maybe all of the valves need to be adjusted to the correct clearance. You may find a loose lock-nut on one of the rocker arms.Well I found out this afternoon from my dad that the head had been changed and is possibly where the different fuel lines came from.
Either way, I tried to start it and got this----well I recorded it but can't load. It turned over steadily for what I would say in through 3 cylinders. Then the next one was a tsssh, like air blowing. The cycle repeated.
Can I load a video from my phone to this site?
Tinkerer, you are correct. Head was changed, but many years ago. I cannot say if the old or new injectors were used, but according to the way the injectors mount in the 2 pictures, it appears to have injectors like the 530B. And the pump that has been on it for years is the pump on it now.
greg, I'll see what I can do about the video.
Okay, can you say if this has ever run with the head that is on it?
But again, it has the same components on it now that it has had for many years and ran.
Ether, yes. No luck there.
I don't know if youtube allows it to be played in slow motion, but I did on my computer. I still can't tell what's happening. I kept seeing white smoke. It mostly appears to be coming from the 2nd or 3rd valve from front of engine.
I would suggest that you have a CNH (Case) dealership technician come out and fix it. White smoke when cranking with a shot of ether and it still won't start tells me you have multiple issues with the timing and the fuel delivery. Keep us updated on your progress.As much as I hate to admit it, I may have to let my fingers do the walking and get some help here. SUCKS!!!
