I was able to get the injector pump off the Case 530CK. But I have something wrong
If I turn it to the 11 o'clock position, the marks will align inside the pump window toward the engine. But shouldn't I be looking at the one away from the engine?
- Valves on front cylinder are closed.
- I see the marks on the clutch or whatever it is
- Injector pump shaft sitting at 11 and 5 o'clock with dot at 11
- I see both marks in injector pump window away from engine
- Dot inside injector pump is at 5 o'clock position.
