Brian K
Thanks again JD. I'll post my progress and results. Hopefully the kit will work well.
Here is how I plumbed mine.View attachment 285366
How do I open thisHere is how I plumbed mine.View attachment 285366
Did you get it working properly?Thank you so much , I'll try those things and see what happens.. I had the same left over parts
Is that the only shim you put on the plunger? I put two on top and two on the bottom as I thought that's what the instruction stated for stock. I am still experiencing bogging issues. thanks
The Tee fitting that you are speaking of, is that only because you are running a Deere ? Or do the 120-2's need to have that also ?Here is how I plumbed mine.View attachment 285366
