Hitachi 120-2 questions and anwsers
Discussion in 'Excavators' started by SoutheastSavage, Sep 27, 2020.
  1. Garter
    Garter Member
    Sep 7, 2020
    13
    Ireland
    No problem, as I said if you need more detailed images just shout.
    JDCrow and SoutheastSavage like this.
  2. bdward
    bdward Active Member
    Sep 11, 2014
    28
    alaska
    I just got a EX100-3 that may need the conversion kit but I haven't done any of the diagnostics yet. There is NO electrical control of the throttle and to even start it and I need to hold the pump throttle control with a wedge to set the speed. I ALSO HAVE ONE OTHER ISSUE I HAVEN'T HEARD ABOUT IN ANY POST. I don't have any electric control for track speed. It's fixed at slow speed. Is this part of the problem a conversion kit will fix? Your responses are appreciated.
  3. SoutheastSavage
    SoutheastSavage Well-Known Member
    Sep 27, 2020
    46
    Kasaan Alaska
    so With your throttle control, conversion won’t fix. You can check the EC. Motor throttle motor to see if it’s getting power if it is make sure your throttle cable isn’t bound or seized. ?? And if your machine functions fine as far as not bogging when you use hydraulics I wouldn’t do the conversion. If everything works fine except throttle and track speed. I would try to track those issues down. If machine does bog and has other issues. Throw a manual throttle in and get a conversion kit on it
  4. bdward
    Sep 11, 2014
    28
    alaska
    Thanks for your response. So far by jamming a screw driver between the pump throttle shaft & stop to speed up the engine, I seem to have proper hydraulic operation. Is the conversion kit mainly to replace the computer signals that maintain the proper pump stroke during a load and nothing about the throttle motor control? If so I see your point. I'll check those functions. Fortunately I have the books though their sometimes hard to follow. Need to get on this as it's starting to cool down here in Delta Jct. - Thanks again
  5. SoutheastSavage
    Sep 27, 2020
    46
    Kasaan Alaska
    Yeah your right there. I would suggest checking for power at throttle control. If there is power and nothing is working consider buying a new one. I think they are about 150 bucks on eBay. Or Friday parts.
  6. EZ Repair
    EZ Repair Member
    Jan 22, 2019
    14
    Bacolod, Negros Occidental, Philippines
    Garter likes this.
  7. SoutheastSavage
    Sep 27, 2020
    46
    Kasaan Alaska
    This is the instruction for the conversion kit that I have been able to find. I haven’t installed my conversion yet. But I plan to soon
  8. SoutheastSavage
    Sep 27, 2020
    46
    Kasaan Alaska
    Haven’t been on in awhile and I just wanted to let everyone know that I did the conversion on my 120 today.
    After conversion I experience no bogging and plenty of power. I haven’t ran it for a long period of time but so far am very pleased. Conversion took about 3-4 hours and was fairly easy to do. Instructions are not great but good enough. I took some pictures of my work today here they are and cheers everyone that helped and gave me info and pictures it helped a lot
    Garter, alaskaforby4, mg2361 and 2 others like this.
  9. SoutheastSavage
    Sep 27, 2020
    46
    Kasaan Alaska
  10. SoutheastSavage
    Sep 27, 2020
    46
    Kasaan Alaska
  11. SoutheastSavage
    Sep 27, 2020
    46
    Kasaan Alaska
    If anyone needs advice let me know I will be installing a manual throttle tomorrow and will add some pictures of that
  12. JDCrow
    JDCrow Well-Known Member
    Sep 25, 2020
    102
    Redmond, Or
    Still and option for me. Still dealing with boom up. Thanks for pics. It does look pretty straight forward
  13. SoutheastSavage
    Sep 27, 2020
    46
    Kasaan Alaska
    Yeah after running machine a little I noticed that my stick in. Is very slow and sometimes can only do one function at a time can’t boom up at the same time. Thinking about putting more shims in conversion any input ?
  14. LACHAU
    LACHAU Senior Member
    Aug 11, 2009
    514
    Saigon, Vietnam
    1. "..stick in. Is very slow" If single action, It relate to "DIFFERENTIAL PRESSURE CONTROL" to increase pump flow.
    2. "..can only do one function at a time can’t boom up at the same time". It relate to "PRESSURE COMPENSATION PROPORTIONAL SOLENOID VALVE" or we can say that is "FLOW SHARING PRINCIPLE".
  15. LACHAU
    Aug 11, 2009
    514
    Saigon, Vietnam
  16. SoutheastSavage
    Sep 27, 2020
    46
    Kasaan Alaska
    So I ended up disconnecting my PVC completely which fixed the issue. My machine works as it should. No pvc and no pump electronics. It is working very well have used it for about 4 hours
    JDCrow likes this.
  17. SoutheastSavage
    Sep 27, 2020
    46
    Kasaan Alaska
    0FD1B603-907E-4C94-A644-6A22BF01DBA4.jpeg EBE0E9C3-F1CA-4CBF-BF6D-F6323DE388BD.jpeg BEEB81D5-EADB-4F4D-A198-5657C74D174D.jpeg 0FD1B603-907E-4C94-A644-6A22BF01DBA4.jpeg EBE0E9C3-F1CA-4CBF-BF6D-F6323DE388BD.jpeg BEEB81D5-EADB-4F4D-A198-5657C74D174D.jpeg
  18. SoutheastSavage
    Sep 27, 2020
    46
    Kasaan Alaska
    So I’m thinking about replacing my bucket pin and bushings. I have a thumb so I’m curious on if I need to get a longer pin and how many bushings ? 6 2 on thumb 2 on bucket 2 on boom ?
  19. SoutheastSavage
    Sep 27, 2020
    46
    Kasaan Alaska
    So anyways I had a machinest look at my machine and is gonna build me a new pin. I have 6 new bushings coming for bucket stick and thumb. I also installed my manual throttle which was very easy to do and works great. Machine continues to work well with the conversion kit. Very happy
  20. SoutheastSavage
    Sep 27, 2020
    46
    Kasaan Alaska
