Robert0769
I sent the pictures of the used parts. What do you think?If it's in one piece it's a sprocket. Yours is in 5 pieces IIRC so they are segments.
I sent some more pictures of the used parts. What do you think?As Bccat says,it’s all in the operator.
Good operators can get twice as much out of an undercarriage as a novice or a highly experienced imbecile.
Fortunately for my little operation,I’m quoting against big companies that accept and understand that you can’t get good men to operate them,so the higher running costs are allready built into their rates.
Rates are allways tight enough,so if I undercut by a tiny margin,or offer a much more flexible service to the contractor,then I can make a bit of profit from time to time.
Nicky, I like " a highly experienced imbecile" ,I've come across a few myself.As Bccat says,it’s all in the operator.
Out of the 6 track rollers in your photo I can see 3 that I wouldn't consider installing even if they could be bought for scrap price. That's 6 rollers out of 16, what do the other 10 look like.?I sent the pictures of the used parts. What do you think?
I won't be in the area again but I believe it was about .8".Out of the 6 track rollers in your photo I can see 3 that I wouldn't consider installing even if they could be bought for scrap price. That's 6 rollers out of 16, what do the other 10 look like.?
I assume there are four idlers but there are only photos of 2 of them, and without seeing them side by side with a new idler it's hard to tell. Is it possible to put a straight edge across the top of each idler as shown and measure the depth at the points shown by the two pins on both sides.? Post up the results and I'll tell you how much they are worn.
That would make them better than brand new - less than zero wear in other words. I don’t believe that for a moment If you can’t measure them can you have someone else do it.?I won't be in the area again but I believe it was about .8".
That seems like less than a new one would be.I won't be in the area again but I believe it was about .8".
.8" as in 8 tenth of an inch?That would make them better than brand new - less than zero wear in other words. I don’t believe that for a moment If you can’t measure them can you have someone else do it.?
Yessiree Bob. A brand new one measures slightly more than that so those idlers in your photos were obviously somehow miraculously adding metal to the tread area while they were working, not wearing it off..8" as in 8 tenth of an inch?
They told me idlers are newer about 80%. Some rollers are newer than others. Some cat brand rollers and some other brand rollers. The pads on the chains are older than the chains/rollers/idlers.Yessiree Bob. A brand new one measures slightly more than that so those idlers in your photos were obviously somehow miraculously adding metal to the tread area while they were working, not wearing it off.
I will see about a measurement, 3/4" is about what I saw when I was there. Didn't take a picture.Yessiree Bob. A brand new one measures slightly more than that so those idlers in your photos were obviously somehow miraculously adding metal to the tread area while they were working, not wearing it off.
No substitute for some cold hard numbers. Post them up when you get them.I will see about a measurement,
80% remaining. Will doNo substitute for some cold hard numbers. Post them up when you get them.
When the seller said "about 80%" was that 80% worn or 80% remaining.?
And 1+ months no date for deliveryOne more point to remember if you do get a professional measurement on that second hand undercarriage………there’s not much difference in an undercarriage that’s 70% left or one that’s 40% left.
Then there’s the 120% worn calculations to consider.
However,if it’s going to cost you a few hundred dollars to get a professional measurement from a supplier,then leave well alone as they’re going to tell you things you don’t want to hear.
And they’ll be right.
I’ve followed this thread all the way, if it were me (which it’s not) if it was my money (which it ain’t) and I had as much work as you say you do, Id rent a machine (or two) and work while I waited for my new Cat undercarriage, which would assure my clients were serviced and Id have an undercarriage on my own machine that would wear for much, much longer than the used one. But that’s one man’s opinion.And 1+ months no date for delivery
I can see your thoughts here, but, there is always a but. Your running full speed doing jobs and taking more jobs. Making money doing good. BUT, you didn't notice, realize, think ahead, or plan for UC wear? It didn't happen overnight. Personally, I am fixing equipment for next summer while i have time now.And 1+ months no date for delivery
