Hopefully later I have time to try out new psi sensor. If not MondayGood to see your problem worked out.
It's hard to tell from the photos. I suggest to put the 2 valve bodies side by side and check if the lands with the O-Rings/backup rings in between them line up. If they do then I would suggest not to worry too much about it.Would the park brake solenoid be a little different? I see the new one has 3 ports and the old one only has 2 .
257-1728 should be the Part Number of the solenoid coill.dk why the new one says #257-1728 on body? I cant see a number on old one
The test procedure calls for a 177-7862 Hose, 2 x 6V-4143 Couplers, and a 6V-3989 fitting to screw into the pressure gauge.I don't have gauges to hook up to oil port. I'd have to get some. Idk what they call the specific ends for the port on machine
I left to go see if I can Barrow some test gauges. I'll check tomorrow when I come back to jobThe test procedure calls for a 177-7862 Hose, 2 x 6V-4143 Couplers, and a 6V-3989 fitting to screw into the pressure gauge.
Now that you have 2 solenoid valve assemblies why not try connecting the machine wiring harness to the "spare" one, then start the engine and move the parking brake switch to OFF. Can you hear/feel the solenoid clicking.? You might even be able to see the internal spool moving.
No. Just one gauge that will read in the 5-600psi range, a quick coupler to connect to port #7, and whatever hose/fittings you need to connect between the QC and the gauge.I only 1 gauge and fitting to hook into #7 or do I need to hook into 2 ports at once
Personally I wouldn't like to contemplate the idea of doing one in the field but I guess it's not impossible.Has anyone replaced that coupler on-site? Or Would CAT want dozer brought into shop?
I have no idea what u are asking?Water bower tank doesn’t want to go down pls help
