D5G XL Park brake came on when using
mike holcomb
ct
Park brake came on when using, checked fuses, all good. No red light on by fuse box. Tried new brake switch and nothing. When switching from FED to REV the back up alarm comes on, running or just Key on. It will not start with switch in the parking brake off position. When turning key on, lights on dash are low oil light, park brake light, and the Elc squiggle symbol is on, Middle lower light out of the 6 on dash. It goes away once running. Serial #00D5GHWGB01130 Thanks for any help
First up, kudos for posting a Serial Number. It makes finding information so much easier.
So what you have when you turn the key on is warning lights #3, 6, & 7 - Then #3 & #7 should go out once the engine is running, right.? #7 is critical. It should go out even when the engine is idling, you should not have to rev it up to make that light go out.
From experience of others on HEF these tractors are very sensitive to the alternator output not being up to snuff. Do you have a meter that you can test the alternator output voltage at Low Idle and high Idle RPM.?
mike holcomb
ct
Yes, good call, I ment to check belt and voltage but it went past me once switch didn't change anything. I'll check right now. Thank You
mike holcomb
ct
Check pos post at alt and its 14.44v when idling. I just happen to add load tester to 1 battery before starting and only showed 12v , im gonna check other battery separate to make sure I don't have 1 bad battery
mike holcomb
ct
Both batteries check out ok, little low when I put under load 100amp, they show 11 & 11.5 recover to 12 & 12.3
mike holcomb
ct
I just touched ground off starter to chassis and it fell off. Someone was here before by the looks. Duct Tape ‍♂️ Let me fix this and I'll respond in a few. Thanks for help
mike holcomb
ct
So I fixed ground cable. Parking brake light still on. Any thoughts on what's next? I read on another post about a solenoid to check on trans? Any idea what one on my model? Thanks
Those voltages don't sound that bad, especially the alternator output.
Time to go looking for Diagnostic Codes I think. Locate the Harness Code Plug connector (CONN 22) in the LH Console right next to the Service Tool (ET) connector. You will need a short (6"-long) piece of automotive wire to jumper various pins in the connector. See the attachment.
  • RENR7313-03 - Diagnostic Indicator.pdf
That's the one - top left. You might have to remove the zip tie to get the connector apart.
Remove the RH half of the connector (the one with the short black jumper cables) then turn on the key. The powertrain electronic control automatically goes into diagnostic mode.
If you read through the attachment tonight and have any questions feel free to ask.
The diagnostic indicator #1 is right next to the ET connector.
mike holcomb
ct
Thank you for the help today
mike holcomb
ct
So today I jumped the pins with wire ,pin 1 and 2 on left of plug, im only getting a 244 code. According to sheet it says rocker switch. Switch is new and it won't start when brake is off so what now? Maybe a wire in plug broken?
That's the first Code on the list. It may even have been created when you replaced the switch.
Try jumpering between Pins 2 & 3 and see if it will erase.
Even if it won't, go back and jumper between Pins 1 & 2 again. That should scroll you to the next Code.
mike holcomb
ct
Ok I messed up, brake switch was off. Now brake switch on, I get a 262 code, says Switch Deceleration?
