Crazy truck prices
One stack mounted on left side with a Farr filter housing on right, one air horn three cab lights,
steel wheels.
What's the best idea for pruning these excessive pipes, I'm thinking a gas powered
cutoff saw.
cuttin edge
NB Canada
Finish grader operator
cutoff saw.
Low over pass. Not a big fan of fat pipes. If they do have them, I prefer a 45 cut to a curl. I had a friend get a bat burn on an un shielded straight pipe. Got out of the passenger door and touched it with his forearm
Joe H
Utah
Cutoff saw will leave little chips that turn to rust spots if you don't get them off ASAP.
Guessing you knew that, but some might not.
Joe H
I've seen some of the milling crews with 4 door international 3 tons . With a fiberglass box with pretty much everything they would need
Those are popular here as well with paving and curb crews. Paving crews have a flat bed with fuel and water tanks.
cuttin edge
NB Canada
Our paving crew's service truck is also their float truck. Similar to the 3 axle tag that moves my little grader. Just a regular cab and a tandem truck
crane operator
sw missouri
Having crew cabs with any sort of flatwork crew is not a bad idea.
Having a full crew that all have drivers license, and legal road vehicles is not a guaranteed event.
cuttin edge
NB Canada
Our sand trucks are all one tons. They had a 3 ton but there wasn't always someone around with a license to drive it.
No doubt. I know some that pick up and drop off like a city bus.
