Are those aftermarket heat shields on the turbo and I assume the muffler? Did the screen stop the sand from causing major damage?
I initially considered this, but this particular system doesn't have a receiver-dryer.Makes me wonder if the Dessicant package did not explode in the receiver.
That leans towards my best theory. The machine has recently had a sandblast and five-gallon overhaul. Customer claims the A/C wasn't worked on at the time, but I have my doubts.Somebody left an a/c line open for a few days and a whirlwind went past?
Not sure about the laggings. I had a quick look in SIS and can't see them, so yes, they may be aftermarket.Are those aftermarket heat shields on the turbo and I assume the muffler? Did the screen stop the sand from causing major damage?
All the spin on ether cans I've seen are standard right hand thread the same as the disposable propane cylinders. Have you tried a strap wrench?Hey Cmark, what do you do when the cylinders of starting aid/ether are seized onto the threads of the adapters? Both the one on my 973c and the champion 740a grader are stuck on there. The threads aren't reverse threaded like a propane tank are they?
Wow. It's been over 20 years since I worked anywhere cold enough to need ether. I'm pretty sure they're RH thread but I could be wrong. I suppose the first thing to do would be to carefully drill a hole in the can to let any ether go, then attack it with pipe wrenches etc.Hey Cmark, what do you do when the cylinders of starting aid/ether are seized onto the threads of the adapters? Both the one on my 973c and the champion 740a grader are stuck on there. The threads aren't reverse threaded like a propane tank are they?
Yes.Do you ever get tired of working on the extremely dirty oil covered and neglected stuff?
I went at it with filter wrench, and crushed the cylinder and spun the adapter, so grabbed onto the adapter with channel locks and thought i was an idiot if the thing was backwards threaded. I don't got the strength i use to, pretty bad to say that when im 32, but my back has made a wimp out of me once again.All the spin on ether cans I've seen are standard right hand thread the same as the disposable propane cylinders. Have you tried a strap wrench?
Must be nice not to need ether lol. I'm sure the can is completely empty, i was using the crap out of it last winter. Every morning for 4 weeks straight, and im sure it ran out within the first week last winter. Placebo ether.Wow. It's been over 20 years since I worked anywhere cold enough to need ether. I'm pretty sure they're RH thread but I could be wrong. I suppose the first thing to do would be to carefully drill a hole in the can to let any ether go, then attack it with pipe wrenches etc.
Plus a zippoI was thinking a barrel of diesel or ATF.
