Cmark's random photo thread
Cheap "old" Geezer
And ALL Clean underneath!!
A great many days I could only wish had my own 963, really was a loss when sold the Fat Allis HOWEVER could not work it long enough to pay for having. Was also Too small for needs, about median between a 941 and 955.
56wrench
alberta
I’m intrigued by the long ramps on that trailer. Are they hydraulically raised? It would appear as though they do not fold in half
Tones
Ubique
Pretty much a standard configuration of ramps here and yes to hydraulics. Some trailers have bi fold ramps mainly for loading machines like compactors etc. I had these made for my truck.
56wrench
alberta
Ever have any problems with the axle housings by trying to lift too much with the loader or three-point hitch? They came out with a truss bar kit to keep the wheel end drop-box housings from spreading which helped, but naturally some owners just used them for jobs they weren’t designed to do.
Tones
Ubique
Never had any problems with the drop boxes but was totally aware of the issues. This tractor started life in Australia with a reach mower at the Brisbane Airport which the previous owner removed and had been fitted with duals all around. He fitted the 3 point linkage. I got it with 2 stub axles but thought if I had any problems with it then I'd fit axles with planetary hubs off a loader of some sort with similar gear ratios. The other advantage of this would be to lower the centre of gravity as I didn't need that amount of ground clearance.
56wrench
alberta
A lot of dairy farms used bi-di’s because they are like a swiss army knife, only with baler twine usually wrapped around the inside of the wheel hubs :) and quite often most of the problems were caused by a lack of maintenance
Tones
Ubique
The 276 was a tractor away ahead of it time. Available with them was 3 point and PTO at both ends of it. No other Nth American made tractor had that.
Sorry to have hijacked you thread Cmark.
