Old Magnet
Yes, the 9H2256 priming pump is an in line version that was quite common on earlier machines. It's kind of a small displacement but it is all brass so there are no corrosion problems. About $30 aftermarket as I recall.
Agreed, the 4W0788 pump shows six interchange numbers but the 4N4314 is not one of them???
Alternatively, if we were to buy a 1832823 (which used to be a 2W2605, and as we can see above, before that 8N0490) we would get a phisically different pump (longer stroke in this case) but the mounting is still the same so it would do the job.
Cmark,
Right you are, I picked up the 4N4314 group number. The actual pump loops back to the
4W0788.
AllDodge,
You did the same thing I did on the oil cooler. 1N4903 is the oil cooler group number. The actual cooler is a 4N2231.
I don't see any interchange between 1N4903, 7C-7744 or 4N2231.
The 4N2231 does interchange with a 2W7590
Wow. Someone's gone to a lot of effort to make that fit. Looks like they've had to "modify" the frame to make it go in!
Are you sure it's not just had a different engine fitted? Does your engine serial number check out OK?
Big difference in the oil cooler mountings....something is not right.
This is what I have been unable to figure out is how to remove it. I removed the front cover and there is a stainless steal radiator in side but I can find to bolts. Looking on the outside I can barely see some bolts and they are very large. If anyone knows how it is bolted on please let me know.
Remove the cooler core and peel off the gasket. You'll find (I think) 2 bolts underneath. Then dig in the crap around the outside and there's maybe another 3 bolts go into the block.
As you've already got the FIP off, you'll have found the ones that go upwards into the governor housing already.
That looks just like the coolers that were used on some of the Detroit Diesel engine I have worked on.
According to a Cat parts book for the D4 I looked up the housing is held on with 10 12 point bolts around the out side of the housing to which the water lines connect. Once you remove the outer housing the only thing that should be holding the cooler core to the engine should be the gasket. Might need to wedge it of gently with a putty knife tapped between the two parts.
The two gaskets are 7C2230 for the cover at $3.50 Inner gasket is 7C1651 at $6.31, both are stock items at my local Cat House, I mean Cat Dealer!
I did find the instructions for this type of cooler on SIS. Send me a private message with and email address and I can send you it in a PDF. Picture quality is not great but might answer some questions.
Ken
Pulled the cover off a few months ago trying to get it off. Did a little prying on the cooler fins but didn't want to pry to hard so I stopped. Mark I think your right about the two bolts, because the one that is listed for it is held on by 2 bolts.
Ken will send a PM and thanks much for the parts list
Alldodge, water in the oil. This can happen when the oil cooler fails, or when the water pump fails and the weep hole is plugged, or when aftercooler fails but you probably don't have one of those on this tractor. there are many other ways but in my experience these are the most common......TIO
