Thanks Tony, for your help, continued advice and encouragement, I will get some better pics next weekChris, I am not super sure but think its worth a verb that the pipe connections from the loader frame to the bucket come in on a 90 deg end or there about not a straight fitting, this allows an improved scope of movement when the bucket is rotated a full cycle range, you might want to check out this point as it could be easy to fit 2 block 90 deg or even 45's positional fittings, it's something that is very hard to get right when you have no reference how the hoses are fitted, the bucket mounting of the pipes I think on all shovels come in on an angle not straight, anyhow you seem to have pulled this knackered bucket out of the Scrap Mans grip and done wonders to make it viable so well done chap.
tctractors
Cheers Shawn, quite a bit of work so far but I think we are on the right side of it now.Mine also have coiled wire springs over the hoses down there. Like tc said all looks really sharp!! You may not need protection from large debris coming straight in and higher up. With the extra length on mine and a 90 deg. fitting they they droop down a good bit.
Its been great seeing your work come along!
Ever since it rolled up on that flat bed I've had a green eye on... cab...winch...third valve.
Sweet Machine Chris!!
Cheers
Shawn
IMO you would be far better creating a new thread for your machine. This link shows how to do it - https://www.heavyequipmentforums.co...estions-answered-hopefully.76199/#post-801587My Cat 977L has an electrical problem. Batteries are up. When I turn on the key and turn the switch to the left for heat, the electric meter does not move. However if I turn the switch to the right to Start the electric meter move to the left showing current going to the starter or voltage dropping showing the same. However the engine will not turn over. All safety item are in place battery cables are tight. Was running OK and starting easy 2 week ago when I parked it. Help! Any ideas
