Pralhad Birdi
I’ll try changing out the relief valve for another one tomorrow and revert. Flushed the engine out today and put fresh oil on as well.From a Caterpillar publication for a 3054.
High Oil Pressure
High oil pressure can be caused by the following conditions.
The spring for the oil pressure relief valve is installed incorrectly.
The plunger for the oil pressure relief valve becomes jammed in the closed position.
Excessive sludge exists in the oil which makes the viscosity of the oil too high.
