Good tips, new to dozers bought case 450, 45% track left, no leaks, no water in oil or oil in water, good oil and trans pressure, no smoke, flushing all brake line, hydraulics, trans, finals, idler, new filters for all, new fuel bowl, have slow leak in right side track adjuster, need to be re pumped with grease every 6 hours usually has slipped 1/2. Trans works, seems same at normal or low temp, brakes slightly differ. Nice to know tap and hi-low shift turn, was idling one brake to turn, very slow but works. Plan to flush hydraulic tank and fuel tank, blow out all the lines using air. Is this on track? Sorry new and stupid this. Is a 1976 unit.
