Jednlulu
- Joined
- Apr 5, 2010
- Messages
- 40
- Location
- Carey, OH
- Occupation
- Sales-Automotive & PSP Brake Manufacturing Company
First thing i did when I bought her I redid the brakes. So, even if I use brakes, especially when cold, she just bogs with slight turn. Same effect turning as if i toggled the levers for transmission. (Intermittent pumps to one brake or the other will eventually turn in the direction i need to go). Now, when she warms up, she'll turn but, same condition as if with using tranny to turn. Mostly bogs down...just like she has no power. She runs much better when warmed up completely but just doesn't seem to have the pushing power she should. When warm she will move quite well (on level ground) with both tracks on high (with no load). She'll turn decently too but, I still occasionally have to toggle. (That's with no load).
I'm thinking it's fuel / engine related because (from an earlier post) it was mentioned that if trans trouble, the engine would continue to revv but the power wouldn't transfer to the rear end. And in my case, the motor bogs, causing (I think) the tranny to lose umph to be able to move.
I'd inquired about the charge pump (inadequate pressure to Torque Converter / Transmission, etc) awhile back but a guy told me that if the charge pump was worn, I'd have to be manually priming it.
When revved high, the torque converter pressure is high. (Can't tell what trans pressure is doing, guage isn't working yet). And, when motor "bogs" I lose torque converter pressure. That help with your trouble shooting? I really appreciate you taking the time to try and help me out Baz.
Thanks, Jason
I just thought....if I'm creeping along and I've got the blade raised up and it "stops" at the end of the stroke, I lose even more ability to move....could I be overlooking something with the charge pump??? This thing is making me crazy!!
Thanks, Jason
