TriHonu
You have to be logged into Facebook before his page will be displayed.
Wonder if it is because I am from Canada. Doesn't seem to work. I went to your website and tried to follow the Facebook link there as well and it did the same thing. Brings me to my home page. I also noticed a number of your video's on your website were blacked out. Oh well, thanks for trying. I could see the pics on your website. Looks good.
Lick on the link - login to your acct - then come back and click the link again. Should get you there.
What joystick control(s) do you use for the grader functions ?
Same thing exactly Happened to Me KSSS ….. I thought it was another internet server thing ….but its not ….
It's really too bad to, because I had been following you on this to see the outcome ….. I used an older version of the grader you bought, but being that I have a Bcat there were no issues with plug'n play as you are working thru …… but the grader was awesome to use ….. for where i'm located (and our local economy) I couldn't justify the grader purchase at that time, but it is on the Back-Burner to get one …. Cheers and have fun !!!
Does the Bobcat send continuous flow to the grader also?
Four switches will be something for me to figure out on my Kubota, if I get one. I have two aux buttons on the left stick, the right has a proportional switch and a continuous flow for each direction.
KSSS, I am looking at hooking up a laser to my Bobcat T770. I want to use the integrated control system. Did you end up with a Bobcat grader? If so, how does the laser receivers interface with the machine. Is there control box built into the grader blade? Were do the cables from the receiver plug in, the grader or the machine? No one at my local dealer has ever seen a set up up close or know enough about the lasers to be able to tell me if I can attach poles and receivers to my machine. Maybe you can take some picks of the cable connections on the bobcat grader and how it connects. That would be awesome
Thanks in advance for any help.
Equip
Perhaps someone more familiar with newer BC machines can speak to what your T770 needs to be able to run the grader from in the machine. I am assuming that as long as you have the control screen in the BC (which may be standard, I am not sure) that should be all you need.
