ala.millwright
Yea I can't figure out why so much oil was coming out of that valve either.but I still believe I've got one bypassing like this on loader bucket also.
Yep the charge pump feeds the main pump oil from the trans sump.I'm not at home so I can't look at tractor but from memory oil leaves main pump and goes to pressure control valve mounted on side of trans.from there oil goes to loader and backhoe control valves from two seperate ports on pressure valve.now I belive oil is feed two reverser then then brake valve by charge pump but this all I can remember. And like you I have no scematic to go by very frustrating.
Whats your serial number and arrangement number, will see if I can get some info for you
Okay I did a little test today.I let tractor idle for about 20 minutes with both trans levers in neutral and reverser also. The trans filter cover got hot and the main pump and reverser also.both loader control valves were fairly hot along with pressure control valve or priorty valve. The brake valve stayed cool. Any ideas if I'm on to somthing here or are these supposed to get hot?
