ok guys I just finished putting a new Pressure Control valve in the pressure control unit last week.. and I had to buy a new 45 degree Elbow fitting that was 75 bucks that goes to the loader circuit as the old one kept loosening.... did I do it right? I threaded it all the way in and had to back it off 1 full turn.... to set the fitting in right and then I turned the nut down and I guess that pushes the O ring in place
so now I wanted to do the O filters.... the rings are bigger then the seat on the filter housing... John deere says this is the right size its just tricky to put on... this seems BS... as if u try to tighten it up she pushed out of the groove and sits outside of the filter housing
I almost have to cut the O ring remove a section and re glue it together
or do you guys have ideas as this cant be right can it???
here some pics
here some pics
