My mm55sr-2 wouldnt even turn over, and it turned out to be the microswitch under the left arm rest that indicates the arm-rests up or down position.
Folks having issues with the micro switch under the arm-- try switching the wires from COM/NC to COM NO (abbr. for common, normally closed, normally open). This was an easy way to check that the switch was stuck in the wrong position. to free the switch, there are two little pins that punch out (fairly) easily. pop the case off, and check for corrosion on the little copper plate, and then remove the rubber nipple with the copper stud in it, and remove the small plastic bumper that directly hits the connection in the switch. the rubber nipple outside the housing and plastic bumper inside the housing should be free floating, and not stuck together.
Anybody have knowledge of what other problems this faulty microswitch causes?
