PRDiesel
Well I got the undercarriage squared away for now but another problem has risen. While working the other day, the machine seemed like it was lugging, throwing black smoke and didn't have the power that it normally does. I figured it was a fuel filter so I changed it, drained in water in the seperator, and cleaned the filter in the banjo fitting on the fuel pump. Long story short, this changed nothing.
I kept working for about 10 min after the fuel filter change until a error code popped up on the screen saying "Pump P2 Propo Valve" with the letters "PSV" in a box next to it and a small "E2" on top of the box. When this code popped up the left track immediatly started acting up (it would only turn very slowly in either direction). The right track was still fine.
After a few min. the left track started working again, and the code went away. Shortly thereafter the code came back on but the left track was working fine. All the while, hydraulic performance seemed down and the machine was blowing black smoke.
The machine is now sitting b/c I dont want to screw anything up. I also cleaned the pilot filter to no effect.
Now that yall are thoroughly confused... what do you think???
