MR. KOBELCO
Resigned
- Joined
- Jul 31, 2008
- Messages
- 433
- Location
- CANADA
- Occupation
- PARTS & SERVICE MGR. AMOUNG OTHER HATS @ KOBELCO D
jonboy,
you can try,
on the display there should be a blue screen change button.
turn key on,
depress blue button one at a time until the hours after engine oil change shows,
then press blue button and hold down not releasing for at least 10 seconds,
you should spot the display screen change then when releasing change back to the hours after oil change.
at this point use either the mode select button or buzzer stop to count the hours up or down. usually the maintenance clock starts at zero and counts to 500 before throwing the alarm. you can override by fooling computer the machine has already had 250 hours clocked this way. I recommend reseting back to zero. 500 hour intervals is best.
when you have counted to zero press the blue button to save it into the computer.
you might also try once you are able to change hours on the screen to push both the mode button and buzzer stop at the same time holding until the computer sets zero,
then push the blue button to save.
you can try,
turn key on,
