Just in case anybody was wondering....
I've been back and forth between the ISO machine and the SAE machines. (I just checked and in my prior post I had the names confused.) The first SAE machine I got on was the Kobelco mini and even though I had the option of switching the pattern I chose not to. I knew that I couldn't switch the pattern on the bigger Kobelco, so I decided to try and get accustomed to jumping back and forth. I've gone from one pattern to the other several times now, although not on the same day yet.
What I've found is that the first ten minutes or so are really difficult, on whichever pattern I'm switching to. For some reason, it seems like it helps to hold the controls with just my thumb and fingers, rather than with my whole hand. Perhaps it has something to do with needing to consciously keep hold of the controls, which in turn keeps me more conscious of what each of them does. I dunno.
I've also noticed that for any given combination of control inputs, I need to do a number of repititions before I get comfortable. For instance, once I've dug a few bucketfuls (coordinating the raising of the boom with the crowding of the dipper and curling of the bucket), it seems to come naturally again. Even once I've done that for a few minutes, if I then try to make a pass pushing out with the teeth to level a spot on the ground (coordinating lowering the boom and extending the dipper while curling the bucket out), it just doesn't happen like it should. I need to do a couple of repititions of *that* before it gets to be second nature the way it should be.
I have to say that I don't *ever* feel as comfortable on either pattern as I had been when I was just running the SAE machines. There have just been a couple instances each day when the machine did something I'm not altogether sure *I* wanted it to do. I'm not positive it wasn't because my hands momentarily got confused without my even being aware of it. I imagine I'd get over that after a couple days straight of just staying on one type.
It is kind of an interesting way to explore the boundaries of your personal limitations though...
