Ford A-66 specs and parts?
Discussion in 'Wheel Loaders' started by Sk187, Aug 28, 2009.
  1. Sk187
    Sk187 Active Member
    Feb 27, 2008
    42
    Holland MI
    Ive been on a hunt recently for a backup/yard loader for our JD 544j's.
    There is a local company selling a Ford a-66 and I think it is comparable to a jd544 in terms of weight and hp.
    Does anyone have any specs or any experience with an a-66?
    Also, are parts available at any New Holland dealer?
    Thanks
  2. salopez
    salopez Active Member
    Nov 12, 2005
    40
    Maryland
    I believe its more on par with a 644.
    mine has a 4 yard bucket, and wieghs 32k lbs
    all parts I have needed have been at the NH dealer.
    may I ask what they are asking for it and what the condition is?
  3. Richardjw~
    Richardjw~ Senior Member
    Apr 14, 2007
    305
    South Devon, U.K.
    It has a Ford 401 cu in. engine which produces around 153 BS HP
  4. jakesdad
    jakesdad Active Member
    Jun 29, 2009
    35
    Langdon, ND
    I recently run across a A66 loader for sale with a blown engine. It is farm equipment dealer that has it but they are holding the price higher that salvage price. But I would be interested if I could buy it right and make some money on it.I know that the engine is slevee less.A short block will run about $5500.Does anyone know what other engines out of tractors might fit?
    i
  5. Richardjw~
    Apr 14, 2007
    305
    South Devon, U.K.
    For a block you need to look out for something out of a Ford 8210, 8700, 9700 or any of the TW range 10 > 35....be aware they had a habit of oing porous, make sure you're noit buying more trouble
  6. fendtman
    fendtman Well-Known Member
    Dec 22, 2007
    94
    michiga
    I think a guy by the name of hinfarm posted on hear with his experience on buying a different engine for a ford a66 loader. he also posted on new agtalk his experience of replacing the engine, in summary, it is not a simple job to fix it. he had an awful problem fitting and getting the parts to do it.
    ? on tranny in a ford loaders, are they a stand allison tranny or something special.
  7. Tequilaman007
    Tequilaman007 New Member
    Oct 15, 2009
    1
    south dakota
    They are an allison. I have a Ford a 64 that has the tranny out again. I have high and reverse but no low. Any one have any idea on whats out.
  8. cummins05
    cummins05 Senior Member
    Jan 4, 2009
    430
    Edmonton
    I ran a ford a64 for my first operator job ever and i would never buy one of these.
    maybe it was just that loader but it was a gutless wonder and always broke and i got paid by the meter hours. I ate alot of kraft dinner
  9. RocksnRoses
    RocksnRoses Senior Member
    Jun 14, 2008
    770
    Owner operater crushing & contracting business
    South Australia
    We ran two A64's for a few years and as a loader to operate, I quite liked them. We did everything with them, from feeding the crusher, clearing trees and cleaning out dams. We had to be careful in dams and on slopes, because they were a little bit tippy, or they gave that impression, but I do think some of that was because the operator was sitting up fairly high. Both these machines were up around the 11 - 12,000 hour mark and the only real problems we had were with the axles. They had inboard brakes incorporated with the diff, which ran in the common oil and they caused a lot of problems for us. The axles ran frightfully hot, but we were running them hard, to keep up to the crusher. The engines gave no trouble, but we did rebuild one transmission.
    I do have the specs on the Ford A62, A64 and A66 loaders if anyone is interested.
    Here is one in action.
    Rn'R.
  10. Image
    Image Member
    Nov 21, 2009
    15
    ND
    could you post the specs to that A62? Or pm me and I'll give you my email if you can email a copy.
    Thanks, Steve
  11. chrishunt
    chrishunt New Member
    Feb 14, 2010
    1
    london uk
    Ford a62 a64
    Hi there. I have an A62 and A64 and we have problems with the brakes, namely the hydraulic brake oil reservoir/pump, seems to allow the fluid in to the engine? Any advice would be most appreciated. Many thanks. Chris, London
  12. RocksnRoses
    Jun 14, 2008
    770
    South Australia
    G'day Chris, crikey, you are really taxing the memory bank now, it has been many years since we ran the Fords. I am wondering if the oil is going into the engine, or into the diffs. I am fairly sure we had a lot of problems with the oil going into the diffs. There are large "O" rings on the hydraulic brake pressure plates in the diffs and when they let go, the oil pushes past. From memory, we used the diff oil, which is around SAE 30 consistency, in the hydraulic brake resevoir, so that it was compatible with the diff oil, when they leaked and we would have to drain the surplus oil out of the diff every now and then. If the oil is going into the engine, it should only be a matter of replacing the seal on the pump drive shaft, but if it is going into the diff, well the whole thing has to come apart. I never did like their internal brakes.
    RnR.
  13. curbappeal
    curbappeal Member
    Dec 29, 2009
    14
    wi
    Hey rocks and roses. Do you still have the specs for the A66? I have one with tranny problems. Please post them or pm me. Thanks a bunch
  14. AdamsExcavating
    AdamsExcavating Active Member
    Oct 7, 2010
    28
    USA
    Not able to PM you, but can you email me the specs for the A62, A64, and A66 loaders? Email is radamsexcavating@yahoo.com. Thanks much!
  15. RocksnRoses
    Jun 14, 2008
    770
    South Australia
    Not a problem, I have sent them off.
    I guess you recieved the specs, curbappeal?
    Did you get the tranny problem sorted?
    RnR.
  16. AdamsExcavating
    Oct 7, 2010
    28
    USA
    Hey thanks a ton, i will look at them this evening. Thanks again.
  17. tdigeronimo
    tdigeronimo New Member
    Feb 3, 2011
    1
    Heavy Equipment student at Pennsylvania College of
    Verona, NJ
    Hey rocksnroses, i realize this thread is a little old, but if you still have those a-64 specs i would really appreciate them. My e-mail is tdigeronimo@gmail.com sorry i cant exactly figure this PM thing out, thanks in advance
  18. RocksnRoses
    Jun 14, 2008
    770
    South Australia
    Done, let me know if you have any problems receiving them.
    RnR.
  19. oriden
    oriden Well-Known Member
    Jan 12, 2009
    189
    Equipment operator/ truck driver/ wrench operator/
    Winnipeg
    We have an A64 for sale :) good shape with new tranny pm for info .
  20. curbappeal
    curbappeal Member
    Dec 29, 2009
    14
    wi
    send info on a64 for sale
