lhlcr
Hey RocksnRoses can you send me the specs of the a-66?
Do you recommend this loader for working on a rock crusher?
Thanks
Thanks
We have an A64 for sale good shape with new tranny pm for info .
Thanks
R&R, do you have any other literature on these loaders? I ended up buying an A-64, And would like to find out the model year. Do you have a way to tell that by the serial number or anything?
So I finally fixed the trans on the A66 for much less than expected. Everyone wanted to rebuid the unit and I replaced the charge pump originally with no luck in fixing the machine. It ended up being the main valve assembally. They wanted almost $2k for a rebuilt one so I bought the parts for $250 and fixed it myself. Pretty easy fix as you can get it off and on without pulling the trans. It is kind of a bugger to get at all the bolts but doable. The have aluminum valves and will get gaulded up if some foreign materials get in there so I took out the valve bodies and buffed the ports by hand (as they were pretty scored) and reinstalled new valves. Put it back together and no lack of power anymore! It will break loose all the tires while digging! Thank God! Total cost was under $1000 and the most of it was $600 for a charge pump that I probably didn't need. Well back to digging!
RnR...the motor seems to be bad in the one we bought (knowing this when we bought it) And we were wondering what we can use to replace it with? Will a 6.6L diesel from a truck interchange without major problems?
G'day Chris, crikey, you are really taxing the memory bank now, it has been many years since we ran the Fords. I am wondering if the oil is going into the engine, or into the diffs. I am fairly sure we had a lot of problems with the oil going into the diffs. There are large "O" rings on the hydraulic brake pressure plates in the diffs and when they let go, the oil pushes past. From memory, we used the diff oil, which is around SAE 30 consistency, in the hydraulic brake resevoir, so that it was compatible with the diff oil, when they leaked and we would have to drain the surplus oil out of the diff every now and then. If the oil is going into the engine, it should only be a matter of replacing the seal on the pump drive shaft, but if it is going into the diff, well the whole thing has to come apart. I never did like their internal brakes.
RnR.
Hi, I need to know the capacity for transmission fluid in the Ford a62 loader, do you know how many gallons it takes?
Not a problem, I have sent them off.
I guess you recieved the specs, curbappeal?
Did you get the tranny problem sorted?
RnR.
