Animal
Greg, sorry I'm a bit slow getting back to you, I've away from the computer. The cap I got was an off the shelf one with 10psi rating, the one that came with the machine when I got it was utterly stufted so was throwen away. I have ordered an origenal that should be here in the next day or two so should be able to tell you what the pressure rating is then and if it's got a return valve on it. I asked the agent if he could tell me the rating but said there was nothing written in the parts book. The one I've got is at 10psi and is just not quite strong enough as it will blow off a little bit when you work it hard. When I got that cap I took a guess at the pressure rating so it doesn't suprise me that it's wrong. I would say that around the 12 to 13 mark wouldn't be far away. Thinking about the catch tanks, we use to make them out of alloy for the rally cars so we could fit them into tight spaces out of the way, the avantage of using alloy was it's a bit stronger than plastic and transfers heat away, but in a dozer application you could use stainless as you don't need to worry about weight and it's a bit easier to work with. We use to put a pipe on the bottom for the suction hose so it wouldn't move and a push-on cap for the top that allowed it to breath. Regards Nelson.
