So long as you do not overheat the hardened cutting edge welding does not hurt it. The welds will be from the lighter sheet of the moldboard to the edge just as at the factory a non-issue. Try to locate an edge with the correct bolt holes, boltings do come loose but not stressing by welding the teeth on.
