Hallback
This is not the post I ever wanted to make but feel I need to raise awareness in this situation. We had a fatality on Tuesday on our new Skagit 737. The Chaser was spooling the main line after they finished logging the setting and either the extension I or the extension shackle had hung up somewhere out in the brush. The Chaser told the yarder engineer to give us some throttle and pull it free while he was still spooling the line. He was standing on the correct platform using a spooling rod and the yarder is equipped with handrails around the drums. When the main line pulled loose from its hang up it through quite the whip into the line and tossed Robbie off balance. He went to catch himself so he didn't fall and got his foot down into the drum and was pulled through the mainline drum.
I along with the fire chief and the aide Lieutenant extracted him from the machine and I just have to say that it was absolutely horrible. He had 28 years experience chasing and was one of the safest employees I have if not the safest. Excellent attitude and very caring hearted.
Labor & Industries was out the same day to do the fatality analysis and commented that that yarder is one of the best they have ever seen and has every piece of required guarding and much more. Please just take a second and go over with your employees proper ways to spool a line and look at your yarders to see if there is any additional guarding or precautions you can take to prevent something like this from ever happening to you or your crew.
Thank you all, stay safe and get logs.
