Who's Run the Largest Equipment?
simonac
quebec
I'm with you, I work in a mine. P&H 4100A with a 56 yard dipper, D11N and R, Komatsu 475, Komatsu 930E 320 ton truck, Cat 793D 240-265 ton truck, 16M blade, Cat 994F loader, and a Cat 5230 Hydraulic Shovel. We aught to start a mining thread!
I really don't think mine should count since I work in a mine. Hoe: EX2500, Cable shovel: Bucyrus 495HF, Truck: 797B, Dozer: D11T, Grader: 24M, Hydraulic shovel: RH400. So like I said, it's not fair to the others to compete is this one.
pretty mutch the same here...i worked in the oil sand of alberta mainly on the rh-400,rh-340,mt6300ac,797,bucy495,p&h4100boss,24h,992,D11,pc1800 just to name a few...think big lolll
Eric
The great Southwest
What's your impression of the 797 and the 24H?? I imagine your road maintenance must be a nightmare with that soft ground.
simonac
quebec
what do you mean impression?? as in operation or machine it self?? cause i dont operate them i repaired them lolll and occasionaly i operate ,mainly to troubleshoot and repaires....they are good machine that work hard as for 797 it all depends on personal preferance of the operator cause i was comparing the 797 to the mt6300ac with the operator and both have good and bad about them,and i dont spend 12 hours a day driving these truck so cant be the best judge...lolll and in the oil sand the ground is one off the worst ennemy even crazyer when wet....the road maintenance is a key element in making the machine and tires survive less bump =less stress on the frame,suspension,articulation,and entire drive train, and the big tire blowout..
and some mine doesent seem to see it that way...as for the 24 h theyr aint any bigger than this but it as all the same issue than its smaller brother,chain drive and circle and bad operator lolll i could go on and on for ever and my trhead is already long enought, hope it is a bit of an anser....
LWG
Reisterstown, Maryland
Case 1816. Single cylinder, 16 horsepower flame-thrower engine. Weighs about 2,000. When it tips forward or backwards, you can hop on the back or the bucket and pull it upright. ; -)
billyboy890
England
driven pre cast piler from the uk currently workin
ok here we go hope they count,this is what l have operated
Cassagrande C60 crawler crane
Junttan Pm23 pilling rig
Junntan Pm20 piling rig
Banut 700 and 500 pilling rig
stuford
Western Canada
the first truck i ran was a 777F followed by komatsu HD1500 and 730E, first dozer was a D10T, first grader was a 16H followed by 16M, komatsu WA900 wheel loader, 330-365 cat hoe, hitachi 850 and 1200, komatsu pc 138 all the way up to pc2000. this summer i will start running 797F, 24M, and D11T. can't wait to say I've run all that stuff before the age of 24!
CraneInnovation
United States
Structural Engineer
Old thread, but interesting....started in 2005 :eek:
Cat 245 and big Volvo articulated dump when I was a kid (got to drive back to the excavator empty a few times)
A Cat D6 when I was 12 or 13. Superintendent let me back-drag a road about 5' from the boom of the brandy-new Manitowoc 777 on the ground...guess he trusted me to not suddenly yank on the tiller!
More recently:
Manitowoc 4100 SII for an hour
Cat 311 and D4 for a weekend
My first personal toy is a Gradall G3WD.
IUOE Man
Floyds Knobs,IN
Operating Engineer
Heres some of the pieces I have ran on a larger scale.Excavators,JD850D LC,Komatsu PC650,Komatsu PC400,Caterpillar 345CL,Hyundai (755,which is PC650 size machine).Dozers,Caterpillar D8H,D9G,Komatsu D155,International,TD-25C,TD-25G.Dumptrucks,Terex 4066,Caterpillar D400E,Payhauler 350B,Payhauler 350C. Scrapers,Caterpillar 613C,621B,621E,627E,#90,John Deere 9400 with Dual 17yd reynolds scrapers. Fiat-Allis 260B,262B.Loaders Caterpillar 988B. Compactors,Caterpillar 825B.Highlift 963B.
BIGKAT Kev
Madison Wisconsin
Working out in Colorado I spent most of my time on D-10T, loved those T model dozers....Also:
D-8,9,10N's/D-9,10T's Crawler Dozers
Triple 7's Mine Trucks
Hitachi 1100EX, Cat 375 Track Hoe
Cat 992 Loader
I loved it out there and running that Big Iron........:notworthy
Desertwheeler
Ca
Miner
MT 4400 haul truck
390-385 excavator
D10's
Letorneau 1350
P&h 4100 A
Cat 844 rubber tire
16H
Those are the biggest I ran before this the biggest I ran was a 992, d9, 350 excavator and 773b.
ol' Grump
eastern Oregon
I guess the biggest machine I've run was back in about 1962, a Euc TC 12 used to push load scrapers in an open pit mine. Two weeks on that and to this day, I swear I can still hear both of those screamers bellowing. Hearing protection back then? Cigarette filters or wadded up toilet paper. ROPS? None, but a hard hat was optional, not a requirement.
mowingman
SE Ohio
Retired
I have operated a lot of different machines over the years. I guess the biggest I have operated would be a Manitowoc 4600 dragline, at a sand and gravel operation.
MEK
SEPA
I unloaded a trailer load of steel with a Link Belt track hoe(2 yrd bucket). JD 624 wheel loader filling spreaders with 900 tons poop in 1 day. Cat 966 with 16 ft snow pusher in a couple snow storms. Mostly farm tractors lately.
wornout wrench
canada
Well, being a mechanic I don't "operate" equipment.
I can make it do its motions, but I really don't think you would want me loading your truck.
I have gone back and forth between logging and mining so have a pretty good assortment.
Largest logging equip would be a Madill 144
Largest mining equip would be a Hitachi 5500
Have played with lots of other things, but like I say, not an operator :rolleyes:
