Ran one of the c series cats the other day. Nice machines to run.
Complaints about the L200 series NHs so far from me. Fan blades all chipped within first few hours, cab does not seal well, very noisy cab, hydraulic system is poor, have to run wide open to go anywhere in 2 speed but then cannot run the boom because the flow is too fast, they don't lock out the pedals anymore and you have nowhere to step but the pedals so you will feel the bucket jerk when stepping in with it running if you hit one of the pedals, the fuse box nightmare, the entire rear plastic design ordeal, its all been a PITA but my biggest complaint has to be serviceability. Boy did NH screw up. Its like they took their focus towards making the cab tilit easily and forgot about the rest of the machine. You cannot work on the engine. There is no access from the sides, the rear access is limited by a very tall radiator, very short engine compartment as well as an upper cover that doesnt raise far, and the front access with the cab up is restricted by the muffler. But the cab tilts up so you can work on the hydros and drives. What do you spend more time working on? Starters, alternators, water pumps etc. I had no issues with working on hydros and drive motors before. It was tighter and yes the cab required special jacks, but at least you could work on the motor. I think NH has built the least serviceable skid steer. We also had a relief valve fail leaving us with no hydraulics, and the quick attach cylinders hoses get hit by some attachements and loosen up. I always seem to turn the wiper on when exiting the cab as well, and I get very angry at the operate button because it is so small and usually have to hit it a couple times, I dont know why they couldnt make the big parking brake rocker switch underneath it do the same thing.
Complaints from other farmers in the are have been fires, lots of fires due to chaff falling through the honeycomb screen in the back and settling down in the engine. The debris all settles on the muffler I noticed on ours, it always smells like it wants to burn up. Another farmer has replaced 3 radiators in 900 hours because of sand falling through the honeycomb and being blown through the radiator essentially sandblasting it to pieces. I don't know how bright their future is with these skids. Maybe some people like them. I dont know. I do like how large and bright the cab is. Visibility is still #1, but it stops there.
