I have two smaller tote sized rod ovens, they are not strong enough to cook the moisture out of the rods so I use an old baking oven, set to 400 degrees until the flux sheath turns a richer gray color, then they go to the totes in small quantities. I will generally buy up to 25# at a time if I know I have a bigger job coming up. I usually buy 5# canisters and don't open the tins(I buy from a welding supply company and not discount stores) until I am ready to cook them up. Once cooked they will stay dry in a old fridge with a single 100W light bulb set in the bottom.
Another old welder trick on suspect rods, stick the rod to the plate and let it start to draw full amps with no arc, knock it loose and then start to weld. On such jobs as here, I will take a torch and heat the local area I will weld for a while on the repeat the process as I move around or await a really warm summer day to sweat out the job.
