joeeye59
I'm not sure if I missed where I can post this other than here? being I'm welding a backhoe I figured its okay?
I have a 310c John Deere and will be ARC stick welding the cracks on the loader and hoe buckets, as well as doing some custom repair patch work on the loader bucket only.
As far as the machine it self it's as solid as can be, no other cracks anywhere at all, just the typical front and rear buckets need welding and repairs.
The issue I have is I need help in choosing the correct welding rod"s".
I'm not sure what kind of metal/steel the buckets are made of, because when looking at the welding rods I see they call out rods for "Low Alloy" "Mild Steel" "Low Hydrogen".
I'd appreciate hearing from anybody. thanks...
Joe
I WANTED TO CUT AND PASTE BELOW THIS INFO I FOUND THAT I THOUGHT WAS HELPFUL BEING IT TALKS ABOUT THE KINDS OF METALS I MENTIONED. ALSO, IF SOMEONE WANTED TECHNICAL SPECS ON METALS AND STEEL APPLICATIONS.
Low alloy steel is gener-ally defined as having a 1.5% to 5% total alloy content. Common alloying elements aremanganese, silicon, chromium, nickel, molybdenum, and vanadium.
Low alloy steels may contain as many as four or five of these alloys in varying amounts.1.2.2.1 Low alloy steels have higher tensile and yield strengths than mild steel or carbon structural steel. Since they have high strength-to-weight ratios, they reduce dead weight in railroad cars, truck frames, heavy equipment, etc.1.2.2.2.
Ordinary carbon steels, that exhibit brittleness at low temperatures, are unreliable in critical applications. Therefore, low alloy steels with nickel additions are often used for low temperature situations.1.2.2.3.
Steels lose much of their strength at high temperatures. To provide for this loss of strength at elevated temperatures, small amounts of chromium or molybdenum areadded.1.2.3 High Alloy Steel - This group of expensive and specialized steels contain alloylevels in excess of 10%, giving them outstanding properties.1.2.3.1. Austenitic manganese steel contains high carbon and manganese levels, that give it two exceptional qualities, the ability to harden while undergoing cold work and great toughness.
The term austenitic refers to the crystalline structure of these steels.1.2.3.2. Stainless steels are high alloy steels that have the ability to resist corrosion. This characteristic is mainly due to the high chromium content, i.e., 10% or greater. Nickel isalso used in substantial quantities in some stainless steels.1.2.3.3. Tool steels are used for cutting and forming operations. They are high quality steels used in making tools, punches, forming dies, extruding dies, forgings and so forth. Depending upon their properties and usage, they are sometimes referred to as waterhardening, shock resisting, oil hardening, air hardening, and hot work tool steel.1.2.3.4. Because of the high levels of alloying elements, special care and practices arerequired when welding high alloy steels.
Joe
