funwithfuel
There ya go again, as I sit here lazy as can be. But, in my defense, its cold outside.
Both of you just a “beasts” to pull off heavy job like this in your age!!!Me an wife swapped out rear idler and loaded for job tomorrow, needed too do something in our spare time this morning, hope this Taiwan made idler last
Still left with pump chirp the way it all started before, gauge is screwed into valve body, line from pump screwed into gauge bottom line from rear pump reads 450, top fitting in valve body has gauge screwed into it and line into gauge, top line shows 900 at idle, switch lines and pressures DO NOT switch, the bottom line to rear pump was reading 450 move it to top fitting now reads 900, move top line reading 900 to bottom it will now read 450, top port on valve and bottom port on valve keep same pressure not pump,Reply 377 check it out. Its clearer than I can explain off the cuff.
I think that with a better understanding of how the regulators work, thanks to mobiletech and establishing your standby & servo pressures is going to serve you well.
Good luck.
He is talking about reducing Negative Flow Control pressure in general, on a the pump that has 900-1000 psi.The only pressure we should be measuring at the MCV is servo oil apply to boom 1&2.
Not necessarily , yet. But more importantly post 393, how'd it go.
Measuring pump pressure, do it at the pump. You have test fittings there for pump A&B . That's where you measure. Servo pressure correct to spec? Are working pressures correct? Do you have equal servo pressures to either side of boom 1 spool? If the spool is not shifting fully, not receiving the correct oil pressure , of course the control pressure is not going to drop off correctly
Boom down , again , controls 3 functions boom 1, boom 2 and boom drift reduction valve.(some folks call it load holding or load check) if any of the three are allowing servo to drain off, or there is a restriction , your spool will not fully shift.
BTW has this behavior started recently, something you've been living with ? I'm wondering if you have an option for grading that may have been inadvertently turned on.
He teed in to NC lines at MCV, and unless there’s flapper in the hose I don’t see the difference where it is tapped to - it is all the same hose from MCV to pumps controller.The only pressure we should be measuring at the MCV is servo oil apply to boom 1&2.
