Ok, I pressurized the radiator to 15 lbs. Absolutely no water coming from anywhere. I am starting to wonder if this is a condensation issue. After about four hours, there was still grayish oil dripping out of every bearing. I wiped out the oil pan and it was extremely clean, no residue of any kind. Put the pan back on replaced oil and filter and started and ran for one hour. Before I started the engine, I checked the level in the radiator. Checked the oil and it is very slightly lighter then before I put it in. Im sure there was a little old (white) oil residue left in the engine, so that probably mixed with the new oil and made it slightly lighter in color.After the engine cooled I checked the level in radiator and there was none missing.
I am at a loss here. Does anyone have any suggestions. I just replaced a extremely worn out turbo, could this have contaminated the oil in any way? Should I just change the oil a few times to get all the old oil out of engine oil pasageways? Is there another way to fludh the oil system? I still have no clue where all this contamination came from. The guy I bought the machine off of was a homeowner that used the machine to build his house, then it was used just to remove snow from driveway in winter, but we had no snow. So the machine sat unused more often then not. Any suggestions on what to do next
Thanks for everyones help
