walkerv
not a work doing but i have spent the last 3 nites reading a post on here about a certain d6c that lost oil pressure , omg is all i can say as i finally got thru the whole post ... I am in aw at the whole post the people triing to help are awsome i would have quit responding in a couple days after all the repeat questions ..
.. on a further note my 836K blew up another egr cooler cat has been working on it for 3 days not sure what he is doing as i have a project in the shop going on now that i have an extra set of hands but im pretty sure he pulled the injectors to get the coolant off the pistons , I would not be surprised if we blow up another engine while its still under its extended warranty , and i would not be surprised if it does that this machine is going to go away , i have a couple theories on the issue one of them is the 1000 degree dpf inlet temp why the F is this thing running that hot that is the temp of the exhuast as it enters the dpf so likely a little hotter still at the manifold which is where the egr gets fed from ,, that to me seems a bit high incase anyone is wondering that is the temp just sitting there idling after it is pulled out of the trash idling for like 30 minutes or so while cat is doing tests and checks on things so its had plenty of time for internals to cool down from working hard , second problem it still has is it never regens due to a soot load percentage in fact it never shows a soot level even though it is enabled and all turned on all ecm have been updated every sensor on the emissions ssytem were recently changed .it does regen but only based on the time limit.. cat would save a ton of money if they just brought us out a new one put our wheels on it and melted this pos down to make more parts . our 2 year old D8T has more hours on it then this 836K has i think it is near 4 years old
