OFF
Hi Off its Robbie I am back and great news after $2600 in parts I have managed to get the old 40f back up and running, my question is I have no control for boom in and out and when I switch from the ground to the boom the engine dies! Can you give me any advice to try on this I am assuming it is a safety (wiring problem) but not sure where to find it!
Hi Robbie, I'm not too sure how a 27N is set up but the 40F had a separate ignition and power circuit for ground and basket that joined up at the main control box. I would start by switching to basket control and then checking the basket for power with a volt meter. Does the basket have an ignition switch? if so, start there. Make sure you have power to the switch and from the switch (when it's on). After that, follow along on the drawings in the manual. If you have no power up there at all, go back to the ground control panel and open it up, see if the wires were taken off the back of the ground/basket switch for some reason. Could be an adventure.
On the opposite side of the machine from the engine dipstick, there will be a valve bank with 2 or 3 valves on it. One of those valves is your telescope. Check for broken wires, and bad grounds.
