OFF
and Welcome back od1! Long time, no see
just look what you've created!
Hi Off
Is it the older ones that have it near the turret? That's where mine is.
Thanks, I will see what is there tonight. Based on the yellow paint inside the engine compartment I am pretty sure it's from somewhere in the 70's, but it only has a little over 3300 hours on it, and the meter works. Runs great just one issue with the Auxiliary Power and the Down control via the Stick in the bucket, already ran out of fuel up about 30 feet, had to call my wife to rescue me....
That's funny. The same thing happened to me but she couldn't turn any of the 3 valves. I had to wait until my son came home from school.
yes, the older ones had it just about anywhere. They standardized after a while. Can't remember if the newer ones still have it stamped into the turret as well or not.![]()
Well, the post my basket and the controls mount to is round and there is no plate or any indications of stampings there, I looked all around the turret did not see any indication of any numbers stamped there, but could be filled with paint, where should I scrape try to expose the SN? front, side, rear of turret and how far down? I would like to figure out for sure when it was made and what model. Does anyone know if there is a spare set of wires that run up to the basket from the panel at the engine? I want to add a seperate toggle for down only tied to the same output that the toggle at the engine uses for down to be used only when using the Auxillary power. Planning on putting a seperate relay that is powered and can power the solenoid directly rather than have all the voltage drop over the roughly 80 feet of wire up to the basket and back. My thought is that by doing this, when i run out of fuel, that control will actually work and lower me, unlike using the aux power and the down stick, which only gave me about 5 foot of drop before it stopped working. Has anyone else encountered this and is this a good fix???
both motors should have 4 lines. Is it the right motor that is leaking all the time by chance? In the maintenace manual, page 2-24, check out figure 2-18 Drive Circuit Hydraulic Diagram. It shows both motors with case drain lines "T"'d into one hose that runs through the swivel and back to the tank.
OFF, SOS!!! I'll go back to drive motor later but I just sprung a leak in the Swing Motor and there's no parts breakdown in my manual. When we took off the cover theres a disk with 2 brake calipers, a hydraulic solenoid to actuate them. We washed it down and tried it, the fluid appears to be coming from under but that area was loaded when we took the round cover off????? Is there an oil ring under that assembly or do you have a parts breakdown on that. More good news an hour later one of the Cutler Hammer Joysticks is free wheeling all the sudden. I hope I can fix it tonight, I've had them apart a few times already.
My "76" 40F has one on the top of the boom near the basket. It looks original!
Still not seeing any numbers, I have over 50 acres of hay to do right now, so unless it's raining I won't likely have time to look any closer, I did look at all these potential locations and it looks like just smooth metal. It is "dual fuel" does anyone have any idea as to when that option was offered, I am thinking it may help me narrow down what year or at least closer? Still pretty sure it's a 40F, but the control panel does not look like the one in the manual for the 40F... Here is a picture of the controls, I know it's not great, but does this help at all to figure out approximate age/model?View attachment 103899
Thanks, I have to say, this site, and you guys are a life saver. I really like my machine and expect I will have it a long time. I do have one other dumb question, on mine the Alternator is actually way way too close to the oil filter, so much so, that the previous owner actually dented in the oil filter to give clearance to the alternator.... The belt appears to be way too short, does anyone know what the correct belt number is??? I see the tension bolt on the belt appears to be in the wrong bolt hole.... Likely due to the belt being too short, the belt also looks suspiciously new...
no breakdown on swing motors, sorry. You'll have to remove the brake and get a look at the seal. Maybe you can get a number off it and buy one at a bearing store. Or pull the swing motor and take it to a hydraulic shop. Have you ever checked the system pressure on your machine?
I do have a new Cutler Hammer joystick though.
