Takeuchi TL130-Problems-Wont Move
tool_king
new jersey
road mechanic owner
What is your email address ? With key on engine not running .When you lower the seat bar do you hear a click from the the relay ?
Dan Parker
Valley Springs, CA
I know this is an old post and I'm hoping somebody will still reply. I have the same problem with my tl130. Can I unplug the proximity sensor and jump it to get it to move? I tried it and it didn't work, but maybe that's because it's another problem. Also if you still have those manuals available I'd greatly appreciate it. Whatever you have for the tl130 would be great.
skata
midwest
i think many think the prox sensor is the issue, when it is in fact a relay issue that the prox sensor activates.
have you checked the relays behind the panel at your feet?
also, there is a bypass plug by the rear door or battery to get the machine to move. someone wrote in this thread about it.
https://www.heavyequipmentforums.co...al-fault-has-killed-all-work-functions.40731/
as for the relays, the black ones are about $50, and the white ones are over $500. it seems the far right relay is what the seat bar triggers, and then that activates the right black relay. i replaced the black one hoping that was my intermitent issue of machine not moving on startup.
tool_king
new jersey
road mechanic owner
Dan Parker
What is you email address ? I can send them over to you .
Dan Parker
Valley Springs, CA
Thanks, I will look for the bypass
skata
midwest
tak relays.jpg well, it appears the black relay was not my issue. last couple days machine wouldnt move first thing in morning. a tap with a hammer on the relay cover got it going. so i'm guessing i need to replace the white relay. where can i get this without having to pay over $500 which one dealer quoted me?
muel1030
Iowa
I have a service manual and a parts manual for TL150 but cannot find a wiring diagram. Anyone help?
tool_king
new jersey
road mechanic owner
What is your email address. It should be on page III-43 of the service manual. If you don't have the correct book .I can email it to you.
