Mike L
If the Arcair/Cat torch is any guide the set oxygen pressure on the regulator depends on the diameter of rod you are using. Anything from 35-45psi for a 3/16" rod, 45-60 for 1/4", and 60-80psi for a 3/8" rod. Oxygen flow is controlled by the trigger on the rod holder.
Mine was used and didn’t come with any paperwork so I ran my oxygen at 50 psi with a 3/8” rod and had no problem burning through it but I bet 60-80 psi would have sped things up a bit.
