steve loving
Tom looks like you have been busy. At least its cooling down a little this summer has been hot did you make the jack stands. Steve
Could be busier Steve, the stands are 12 ton OTC.
They look similar to the ones I see pictured in my CAT service manual. I hope they are strong enough for all of that weight
Are they the ones with the spring loaded castors? I've seen them around,they are very good.
Quality workmanship, kinda lost these days, You inspire me to do better work myself, and maybe expand the skill set a little bit, thanks
tc
Steve, I would like to see the pattern cutter if you finish it.Tom o/a cutting can produce a nice cut with correct tip/pressures/speed your work is proof of that. Have you ever seen or used a magnetic pattern flame cutting machine. I started building one out of 4130 tubing for light weight but never finished it.
Great looking work Tom!! JW
I just refilled my acetylene B tank....$51.00.It has almost doubled in price.I can't imagine having to keep a stock for work like you guys do.Ron G
Ray, I use acetylene, propane and propylene for cutting, I like the acetylene the best, it seems to be the hottest burning.Look into using LPG for cutting. Its a quarter of the price here.
