RRRancher
Cav, thanks for the info on the actuators. I didn't know those things were so expensive. They are proud of them. And I would be careful mounting a box blade behind the dozer. I don't know if it can handle the added stress that the dozer can apply to it if it gets hung on something solid. I broke the arm that attaches my three point to the box blade with my tractor just from pushing and pulling repetitively. That was before I had a welding setup so I took it to a welder near here and he welded it back together and added another piece beside it that doubled the thickness of the arms. I think I would rip the box off the arms before it will ever break again.
I used the blade on my dozer to pull a concreted 2-3/8 inch post out of the ground that was about 18 inches deep in hard clay. I've also pulled up T-posts with it that I couldn't even rock loose by hand. It seems to have quite a bit of lifting force. I have to wonder if forks would do much good on the blade for exactly the same reasons as cattracks said. The angle would be quite different from full up to full down, and these dozers already seem a bit front-heavy to me. Too bad it's not an 8-way blade on them. Then you could angle it up or down.
On the rippers, I have thought about building a couple of attachments that somehow attach to the blade and protrude below it about 6 or 8 inches to be used as rippers in the forward direction only. I've not come up with a design yet, as I have been to busy to worry about it now, but I think it can be done fairly easily. They would have to be removed, or somehow raised to do normal blade work, but if you just wanted to rip a bunch at one time, they should do the trick.
