Readying for the KW
Once again, WISHING I lived far Closer TS, so much available out there that does not here for some reason. Local Yards that salvage HD Class 8s here had nothing, all been sold, MHC found the correct one where it is one of three New Ones that are in system in the US as to Eaton parts locator. You are quite correct again as to Eaton parts thinning down!!
So rain shut much of the business down today, just busy work for now so was asked if I wanted the day off, DID NOT HAVE TO ASK Twice!!
in the shop awhile. Y'all can have a laugh I righted the engine, did some paint work to those areas buried behind other stuff and set the clutch. Bores are clean and burnished, deck is not fully cleaned where will do that once set back in frame. Next up front structure then set it.
BTW, that old 2" spline shaft I swapped in a truck Many Sleeps ago, been rattling around in my toolbox since like 1983/84. Just have to remember to Rotate Counter Clockwise (Anti Clockwise for our Studious UK AU and EU friends) once get all of the assembly into position before tighten down.
