Readying for the KW
Cheap "old" Geezer
Dropped off Income tax stuff to CPA in STL County, bad news is the Stimulus from April is a Reduction $$Amount in any refund might get, do not ask of if Owe.
Dropped by KW, got Floor Mat assembly both seat belt assemblies(In Small parts pieces) two seats and some other pre-ordered small stuff.
doublewide
MA
Dropped off Income tax stuff to CPA in STL County, bad news is the Stimulus from April is a Reduction $$Amount in any refund might get, do not ask of if Owe........
I was wondering how that was going to work... they counterfeit our currency, tell us what a great job they're doing by giving it to us, then make us pay it back???...
Cheap "old" Geezer
Only constants are Death and Taxes!
Only spent $2700 at KW This Time around!! Already did the shop vac routine, removed much of the rat detritus but threads needed cleaned out.
After removed turds sanded and inspected block deck the where cleaning internally will be the most tedious process.
Cheap "old" Geezer
Well the Fun never ends, Iphone 6(Ten + years old has decided no longer likes me, currently enduring a Restore to OE Settings since the last update. Will see how well that evolves.
When I prime a engine oil system, I use the bulk oil metering gun on the hose reel. Remove the twist nozzle on end and have JIC fittings for gun and block.
Pumps the oil system full in no time.
Cheap "old" Geezer
My old tank was a used, cleaned out and fitting welded in, less than OSHA or ASME Qualified LP pressure tank with a Standpipe set in it. Took us three tries to get it pressure tight using a Lincoln Tombstone welder then Sealing the porous welds with brass and a Gas Axe over 35 years ago. Sat in my barn since bought the place in 2009, got really corrupted and I just could not risk using it again, went to scrap. Used lube oil guns in a Garage in OFallon MO years ago, similarly with a box of random assorted fittings. This will last the rest of my lifetime, into someone else's. 8 qt.
