Question about rear air brakes on an 86 F700
Jakex120
Kentucky
Well I'm prepared for the worst on this one..bought a f700 dump not running but you know "ran when parked but smoked bad so needs overhaul"..the truck is complete..manual with the 370 gas..so a towing/junker lot had it listed and I took it at less than $2000..thing is it was hauled to my farm on a row back..very large rowback..so about the rear brakes..story from the hauler is that the rear brakes are applied/engaged due to the compressor so the truck was slid off the rowback after oil was poured out in the tire pathways of course. I guess I'm wondering if the rear is just locked up and they knew it or is there other reasons the rear wheels didnt move..Not experienced at all in medium trucks and would appreciate hearing the suggestions and experiences..going into this I kept the attitude that it's a parts truck that maybe I could get running at my farm only..thanks
funwithfuel
Will county Illinois
Mechanic
86 F700 with 370 lima engine. I'm guessing you probably have the dreaded Lucas-Girling hydraulic brakes. If you have 2 large brake chambers pointed inward with 3/16 brake lines jumping from one wheel cylinder to the other on each rear then that's what you have. The park brake side is simple enough. There is a 3/4 nut stakes to a threaded rod in the center of each canister. Chock the wheels and back those threaded rod until you feel a firm stop. See if it rolls.
Please see attached pics.
Jakex120
Kentucky
Spring lock brake cans more than likely and with out air pressure you can’t release them unless you cage them but with doing that you lose your parking brake
Yep..that's what I have back there...and just caught a youtube video of caging them...thanks
Jakex120
Kentucky
Man..dodged one there..I guess I should be glad I don't have those lol
Jakex120
Kentucky
Ah..I see..must be some the worst brakes ever and expensive to fix..to be honest the standard hydraulic power brakes I have read about would've been idea..
Do types of braking systems have anything to do with tons/lbs the truck can safely haul? ...or does that(tons) depend on what the bed hydraulics can dump?
funwithfuel
Mechanic
They were basically wedge brakes, but hydraulic. S cams replaced wedges, and now air disc(boondoggle big step backwards)
Lucas was a p!ss-poor attempt to make heavier trucks (up to 30k) sneak in under CDL requirements. They were legal, up to 26k because they were hydraulic not air. They never should have been. Glad you got air, kind of a unicorn. 370 glasser with air brakes. You gonna post those pics?
Birken Vogt
Charter Member
Grass Valley, Ca
We had one with full air, it had the big BW diamond brake pedal and colored Synflex hoses everywhere. The front brake cans were the tiniest I have ever seen, whatever size they were.
