So how long do you figure before its back in action? What is the dolly you are thinking about scrapping?
Nedly, I can only go at slow pace because of all the detail I am doing. If my dump truck blew up tomorrow I could actually have the truck running in a few days but at this point it's going to be a month I'd say. The only big things left to buy are the tires and seats. The rest of it is here...although the truck appears to be stagnant it's getting real close.
These Talbert scraper trailers are on Truckpaper now for $15k.. I could be beating up a dead tree but it looks perfect for my work and I could get that thing anywhere and I get in places often that my tag and dump can barely make. It's low which I love. I feel like I have to crawl around curves with a loaded tag a long.... which I'll be towing too.
This Etnyre is from post #68 it sold on an online auction for $9500
Hey Fastdirt,
Looks like one very nice truck build.
I was interested in your thoughts on why you went with the compound turbo set up. Around here guys are going to single turbo. Claiming to get better MPG and nicer running truck.
Looking forward to seeing the finished rig. (I am sure you are to)
keep up the good work.
Steve
Thanks, farmerlund. The single turbo is the way to go up to around 850hp. After that it requires such a big turbo that if you run just the single big turbo you will have turbo lag, unburnt fuel, and more heat. The big Perkins turbo would be used either way if you were going single or compound. Running the big Perkins in a single will peak more horsepower but not much more and the story from actual real world results is the compounds will out pull the single off the start and the response is just better. The fact that it will be less smokey with compounds and a bit cooler along with better response sold me vs. a peak dyno number. The small turbo is waste gated to allow it to free flow once the big turbo takes over.
I am beyond ready to have it finished. It's just escalated so far that I could've never imagined it would go this far when I started.... but here we are for so many reasons good and bad.
Looking good sitting in there !!!! its a milestone day !!
Thanks.. Huge milestone!!! I have lifted, transported, and worked four Cat motors at this point and since I set the engine I have jumped to other areas in need of a break in the engine department. It's all enclosed in the garage now and I installed an a/c unit over the weekend... Having a small garage is actually nice when it comes to cooling. Stays in the upper 70's barely but a huge contrast to the upper 90's heat index numbers outside.
Oversized cool air charger from Dura Lite just came. It's a bit thicker and much taller. It's all aluminum so it's getting sanded and polished with a "respirator" on of course Ironworker
Jacked the cab up to replace the body mounts. Being a unibilt it only has two body/cab mounts and the two airbags at the back of the sleeper. I did replace the motor mounts too before setting the engine.
Need to go dig up some dollars now.... This has been an all consuming ordeal to say the least.
