Coaldust
- Joined
- May 9, 2011
- Messages
- 3,354
- Location
- North of the 60
- Occupation
- Cargo Tanks, ULSD, RUG, Methanol, LPG
Nige brings up a good point. Sometimes we do stuff and forget why we do it. The reason we originally chose Powerservice with the Afton Chemical lubricity additive was because it was compatible with the mono acid based lubricity additive that Tesoro was selling at the Port of Anchorage terminals.
That is an important point. If you wish to add a lubricity additive, it needs to be compatible with the fuel you are purchasing. Yes, bad things can happen if you don’t. I’ll add a link to a paper you can read to learn why.
Fuel lubricity additives are either acid-based or neutral based. Two types of acid based additives- Those are:
Mono-acid (single long-chain polar end molecule
Acid-based dimmer (double long-chain end molecule
Neutral based:
Ester
Talking with my colleague who knows more than me, he explains that about 50% of the fuel in the North American market meets the D6079 HFRR rig test under ASTM D975. Why? Because nobody monitors it.
Why does your Detroit DD15 owners manual say don’t use additives? Not because Detroit doesn’t want good fuel lubricity, it’s because they have no idea what fuel you are purchasing and what additives you are going to pour in the tank. It’s too complicated. Too many variables at play.
Neutral based:
Ester
